hi, I have to show neck-less (half circular rotating view)view for my menu in android and on the movement of finger from left to right it should move to left to right and vice verse, to implement this i have used this tutorial "http://www.codeshogun.com/blog/2009/04/16/how-to-implement-swipe-action-in-android/" but the problem is the movement of icons is in straight lines path not circular and also i m not able to show multiple icons in same screen , i m only able to show one icon at a time .....pls some one help me i m in urgent help
thanks and regards
focode
thanks and regards
focode
