Help How to sync 2 bluetooth speakers to Note 8 besides Dual Audio?
Hi all,
I have a Note 8 and I've been trying to use Dual Audio to sync up 2 bluetooth speakers to my phone to play music... but there is a slight delay. Are there any alternatives? The delay makes it useless.
Are the speakers of the same brand and model? Because different bluetooth speakers even with the same brand could have differing latencies, meaning whatever you could do on the phone, if the receiving speakers have differing latencies, then they will always be not in sync.
on the app itself, it states "The 2 connected devices may experience a slight difference in sound output", so this is likely what you are experiencing.
you may try to move the phone closer to the speaker that has the delay and see if that may help, but its likely you wont be able to get this to work in the way you want it.
this feature shines its best when its two separate bluetooth devices (i.e. two headphones) ...
the second half of your subject:
you should use a speaker system that can connect its speakers directly to one another , like the JBL Extreme (I have these). for example, you can connect several speakers directly to one main speaker and it will stream to all speakers. there are other companies who offer these speakers.
We can do anything with software besides move physical objects without intervention. Synchronization of audio phasing is just not perfected yet. It can be done across any version of Bluetooth devices with a latency output app. Any brand, any model as long as you are able to stream from any generic built in Bluetooth output (without special apps for output). Think about it, we are only changing the phase of 1 audio channel output to synchronize. It is sad this day in age that there is nothing available to do exactly that. Since a mic is built in we should be also able to automatically synchronize by using an app. This is for an immediate position of where the app is used. I would agree if we were speaking of different size speakers and acoustics of a room and the synchronization properties, but for a basic phase delay app this should have been available for at least 3 years now....Will the real software developers please stand up. lol
