King Mustard Well-Known Member Jul 4, 2014 #1 How can I tell if my phone is in USB 3.0 mode whilst plugged in? It's a blue-ported USB 3.0 cable.
AZgl1500 Extreme Android User Jul 4, 2014 #2 I don't know of a way to 'detect that', but for sure, you will know when you time the file transfers. If they zip from the phone to the computer, it is USB 3.0 if they just drag and drag, it is the old 2.0. Does your computer actually support USB 3.0? if it does not, then the phone will connect in USB 2.0 mode
