how to toggle to use edge only
judicious
is there a way to toggle or even an app to use edge only? i have the htc aria, and can't seem to be able to select network. it's greyed out, and not sure why.
it's my first android..so newbie questions..
thanks!
You should be able to go into settings, select wireless & networks, scroll down and select mobile networks. There you should be able to select whether you want to use 3g or 2g.
I forgot you're on AT&T. I'm not too familiar with the Aria. Maybe AT&T has blocked that option. I can definitely look into it for you.
Just curious why you want to use edge only? I just got my aria and I live in fremont as well
Both of y'all should have waited until the galaxy s came out. Lol. Sorry had to say it.
@judicious I'm still looking. Nothing so far though. May have to go to AT&T store and test one out myself.
