Help How to transfer memos from LG Motion ---> Galaxy S5
AppleUser
Using my Mac laptop, the Memo folder in the LG Motion has multiple files 1_scr to 98_scr . How to transfer these memo entries into the S5 ?
EDIT 10:30PM
I added a few memos in the S5, then using my Mac and Android Transfer, looked at the card and internal phone files and folders. Could not find the three memos nor was a folder modified at the time the memos were entered. Where in the S5 are the memos stored and why couldn't they be seen ?
What's the name of the folder which has Memos ? Why did Samsung make it inaccessible ? Installed it. SmartSwitch does not list "memos" as an item. Will launch it on both devices tomorrow and see if notes = memos.
I used Data Pilot to transfer info. Had I known about this SS, would have used it instead.
Thanks.
UNFORTUNATELY, Smart Switch does NOT appear on the Motion's Play Store. Is it because the Android version is 4.04 ?
Found "InkPad Notepad" on the Play Store. It forms a visible folder in the phone, and each entry will open in NotePad on a PC. Cannot edit it, however.
