startac4 Well-Known Member Oct 30, 2022 #1 I 'm tired of continually correcting the "auto-corrected mistakes" in text messages. It's more of a bother than a help. How do I turn it off? There isn't an "auto-correct" option that I can find in Settings. Last edited: Oct 30, 2022
M Member 1919122 Guest Oct 30, 2022 #2 What keyboard are you using? Your auto correct options will be in your keyboard settings
startac4 Well-Known Member Oct 31, 2022 #3 I'm using the default keyboard: English - LG. I don't see any options in Settings.
M maggiem2481 Member Nov 1, 2022 #4 I am also getting irritated by the auto-correcting in the text messages. Don’t have any idea about disabling the "auto-correcting" option.
D Deleted member 2157292 Guest Nov 1, 2022 #5 This is what I found for an LG G8. I don't have an LG: : https://www.lg.com/us/mobile-phones... screen, touch,) > Keyboard height and layout. SwiftKey has its Settings on the keyboard extended top bar.
startac4 Well-Known Member Dec 15, 2022 #6 It took a while to figure it out on my phone - the Recent Apps Key noted in the instructions did nothing. Here is the sequence that works: Home Screen ➔ Settings ➔ Language & Keyboard ➔ LG Keyboard ➔ Auto-correction ➔ Press English ➔ Select Off
