Help How to turn sound off for sms/mms delivery reports?
Hello,
Can anyone advise on how to mute the sound for sms/mms delivery reports? New phone and it drives me nuts every time I hear the notification sound for sms only to find out its just a delivery report. Ive tried searching for delivery report on the S20 but nothing comes up.
Thanks in advance
Wonderland
Do you need the delivery reports? Turning them off would fix that.
Otherwise it may depend on which SMS app you use (I assume you are currently using the stock Samsung app, but as I don't have that I can't check settings). However none of the apps I have has a separate notification setting for delivery reports (I haven't used them for a long time so I can't recall which apps did what in terms of delivery notifications).
