friendslover21
How do I unflash my samsung galaxy s5 phone?
Q. How do I upgrade from 3G to 4G?
A. This cannot be done with a 3G phone. To use our 4G services you will need to get a compatible 4G LTE device, as well as a Page Plus 4G SIM card. The account will also need to be on a qualifying monthly plan of $29.95/month or higher. If you have a 4G device that has been “flashed,” or reprogrammed, to work on 3G, then you will need to check with whomever flashed the device to see if they can “unflash” it back to 4G. Devices made for any other network cannot be used with Page Plus 4G LTE s
