Hi, my wife has brought my old HTC Desire 510 back into use! However, much software won't run on Android 4.4.3. I have run the software update and it says no updates available. Anyway to get a later version on the phone, please?
The HTC Desire 510 is a dated model and has only marginal hardware specs so there is that. Another issue is there are no Samsung stock versions of Android that are newer for this model. Given there are both hardware and software limitations, it's not a very good option if she wants to use this phone as any kind of daily usage phone. https://www.gsmarena.com/htc_desire_510-6608.php
It will work out if she readjusts her expectations to a minimum but I'd suggest just buying something more capable: https://thewirecutter.com/reviews/best-budget-android-phone/
