How to use AWS API Gateway generated SDK with Android Volley
I am using IAM secured API gateway with access key, secret key and an api key. I have previously used the sdk as follows:
BasicAWSCredentials cred = new BasicAWSCredentials("ERQWFSDGFDSTGFDAGVFSD",
"FADSVXXCGDFHBXVDSFDDGFBFSD");
StaticCredentialsProvider credentialsProvider = new StaticCredentialsProvider(cred);
ApiClientFactory factory = new ApiClientFactory().credentialsProvider(credentialsProvider)
.apiKey("GFDSATRFGEDHFGHBDFTY6ERTYGHJKJHDFGTRTUJJH");
final MyTestApiGetwayClient client = factory.build(MyTestApiGetwayClient.class);
ApiResponse apiResponse = client.execute(request);
This works fine.
My question is how to use the SDK with Android volley library (StringRequest/JSONObjectRequest). I don't want to manually calculate the aws authorization signature and add it to the header, but instead I want to use the sdk.
Note: I don't want to use the output model as recommended by AWS as I am not mapping the responses.
Thanks in advance.
Dawit
