How to use Bettercut with downloaded icons on SDCard?
Hi!!
I have "Bettercut" installed and its awesome! My question is this, I downloaded some icons and copied them to my SD Card, but how do I select them for my better cut shortcut. I only see the options…
  • Pick picture
  • Crop picture
  • Pick from iconpack
None of these show the png files I downloaded.
They have to be in a folder on your SD card that BetterCut is aware of. I use AwesomeDrop to get icons on my phone and when using BetterCut it shows me the "Drop" folder when I select "Pick Picture".
Hi!!
I havfe bettercut installed and its awesome! My question is this, I downloaded some icons and copied them to my SD Card, but how do I select them for my better cut shortcut. I only see the options
