How to Video your screen using built in recorder
Hello,
I am trying to find out how to use the supposidly built in video recorder om my lg g6. I recently installed the latest update (8.0) and was told how to be able to do this but i can't seem to find it. I would like to be able to take a video of a game on my phine.
Any help would be greatly appreciated.
Thx.
Hello,
Thx.
Just open the app and it should prompt you on how to use it. Just press your screen recorder button and it should have a floating toggle of the app on your home screen. Long press the semi-transparent toggle then 2 or more toggles will highlight on the side then click the one that you desire to run your record screen. Now while this function is in operation, it will record everything that you do on your screen video chat text texting apps whatever it will recorded it. Or you can use apps like these:
[moderator redacted]
Sorry, I was seeing some paid apps on that site. Please refrain from linking to sites that promote piracy. Keep it to the play store if uncertain.
Thanks.
