how to view all widgets
wwatfa
ok,
this might sound a bit dumb, but i have been searching for the answer on the internet and i cant find an answer !
here is the dilemma :
if you have more widgets that can fit the 11 pages on the s3 ! how can u view them all ...
ok, rephrased ... first: is the number of pages under (app) in s3 limited to 11 ?
second: if yes (and i am guessing yes) then how to view the apps or in my case the widgets on those non showing pages ??
when i delete an unwanted widget, another shows up because space was created on the 11 pages available !
this is seriously driving me loco !!
Which screen are you talking about? Home screens or the side menu when you go to apps.
My home screen doesn't automatically put widgets on but does add app short cuts if I download something new.
The side menu on apps, just lists widgets that I long hold to put on my homescreen. I have 17 pages in total and the 17th has 1 widget listed on it
They must be talking about home screens because you can't delete widgets from the app drawer pages.
ok,
Just checked mine, it looks like it only shows 11 dots (pages) but when I counted mine there were actually 19, when scrolling the highlighted pages stopped in the middle for a bit then moved. Weird, but for sure I had 19 pages. Try counting to see, or add more and see if you get more pages without it actually adding the dots
