Doris Barney
I wanna resel my old Samsung galaxy s6 device on online, so I need to erase all personal data on it. is there any way to completely erase data on galaxy s6?
If you want completely erase everything then you have to shutdown your phone and follow the below steps.
- Press and hold Power button with Home + Volume UP buttons simultaneously.
- When the Samsung logo appears, release the “Power” button, but continue to hold “Home and Volume UP" button
- When the Android logo appears on screen appears, release all buttons.
- Use the Volume button to toggle the selection to “wipe data/factory reset“, then press “Power” to choose that selection.
- Use the “Volume Down” button to select “Yes — delete all user data“, then press “Power” to choose.
- After erase everyting it will ask to “Reboot system now“. Press “Power” to choose that selection.
A simple solution is to just try and do a recovery yourself then. If your phone's internal storage is already encrypted do a Factory Reset and see what happens for yourself when you use one of those utilities to restore your data. If it isn't go into the Settings menu and encrypt the storage, and then see what happens when you try to restore your data.thanks.. but i heard that factory reset can't erase data completey and it can be easily recovered by some data recovery, right ?
see this:
https://www.safewiper.com/tutorials/how-to-delete-text-messages-android-phone.html
I was worried!
