How to write code to disable screen timeout for certain selected applications in android?
  • Thread starter Thread starter nramesh1990
  • Start date Start date
N
nramesh1990
Guest
I want to create an application or a setting menu under Display settings to disable screen timeout for the selected applications
Please help me.
Tasker can do this - I use it to disable the screen timeout when running certain apps.
I don't know how to add this to a ROM though, which seems to be what you are asking.
