Hello, welcome to Android Forums, I'm rabidhunter. Tap the wether widget, that should bring up the weather. From there, you should see three horizontal bars or a gear icon. Tap on that, it will take you to the settings. You can change the default location there.
If this does not solve your problem, please repost your question. Thank you so much.
