how to
  • Start date Start date
A
Android Question
Guest
How do I take a picture of my screen with the droid razor?
1. If your cell phone has Android 4.0 or later press and hold the Volume Down and Power buttons at the same time for a screenshot.
2. Some manufacturers have a special shortcut - check your manual to see if yours does.
3. If your phone is rooted you can install an app like Screenshot:
https://play.google.com/store/apps/details?id=com.geeksoft.screenshot
4. For a non rooted phone you can buy this app:
https://play.google.com/store/apps/details?id=com.edwardkim.android.screenshotitfullnoroot
5. You can also use Android SDK:
How To Take Screenshots In Android Using Android SDK
