reexx
I've had my htc one m8 for three weeks and managed to drop it down the toilet I put the phone straight into rice and left it for a day only after I read online I should have left it for longer but my phone came out working fine the only problem was watermarks inside the screen which I can live with so I put the phone on charge for about half an hour and it went up to 4% yet after it died and I put it back onto charge it goes to 1% and remains this way yet every now and then I'll get an explanation mark on the battery sign whilst it's charging or a red x But then it will go back to charging I also noticed an orange light that keeps flashing (I do not have an android charger so it does usually charge a bit slower but not to this extent) yet I have tried multiple chargers I dint really know what to do so I decided to put it back into rice and see if it makes a difference (which I doubt) is there any solution to this and if I was to get it repaired what would the problem be? Water damage, a new battery or the adapter? I also checked my battery usage type thing and it said overheated with a red bar next to it? Thankyou for any help
