Help HTC One X Wifi Issues : Advanced Wi-Fi Setting
jsyong
Dear All,
I am having the same terrible Wi-Fi performance issue after JB update like most of you. I have changed the Advanced Wi-Fi setting below and the results is better and at least the Wi-Fi connection will NOT drop.
1.) Connect to your Wi-Fi
2.) Goto Setting and tap on the Wi-Fi (Which show On and Connected to your own Wi-Fi SSID)
3.) Tap on the Menu (Top right hand corner)
4.) Tap on Advanced
5.) Tick on --> Best Wi-Fi performance (May consume more power)
You may try this setting and all the best :)
