HTC PHone Blinking Red Light
  • Start date Start date
A solid red light would mean charging.
Blinking red means that there's a problem with charging. It could be overheating (if you run games while charging, for example), could be a problem with the charger, could conceivably be a problem with the phone. We'd need more information to really diagnose and suggest a fix.
In case it's overheating, try just letting it cool before attempting to charge. Otherwise check there's no fraying of the charger cord, or maybe try with another charger (if you have one) or via usb (or if it's happening when using usb, try with the wall charger or even a different usb port).
Otherwise you could post again with more detail about the phone and when you get this problem, or if you prefer register and post in the main forum where we can discuss it better, and hopefully we can identify the likely cause.
Welcome to Android Forums!
With my HTC Rezound, if I use the phone until the battery actually dies, when I first plug it in the light flashes red. After a while the charge light then goes to solid. This is, of couse, with the phone off. If you are charging the phone while it is on and seeing this, Hadron's post is correct.
I hope this helps! If not, there are two avenues: You can re-submit your question with additional info the same way you submitted this one, or you can join the forums for a better back and forth exchange of info.
If you choose to register, here's the link:
Register today!<----Link
