HTC U11: How to enable Advanced mode for Edge Sense
Edge Sense allows you to squeeze to do certain things, but with the Advanced mode you can also squeeze and hold to do things. Here's how to enable it.
  1. Go to Settings > Edge Sense
  2. Select the Enable advanced mode check box
  3. Set the squeeze force levels
  4. To change what happens when you squeeze and hold it, tap Customize squeeze & hold action, and then choose your preferred option
