Help Huawei Ascend 2 startup issue
When I turn it on, it goes past the logo screen to a black screen with a green circle in the middle. Status Bar will slide down, sound can be changed with side buttons, and it had force closes that repeat such as "(process com . bartat . android . elixir)" and "huawei . keypadprogram".
It goes to my screen lock sometimes, but when I unlock it, it goes back to original black screen.
I'm having the same issue. Tried the reboot several times before I ended up doing a factory reset. I've reinstalled all apps but Jorte calendar (no problems prior to that app installation) and is now working fine. I've turned it off on on 3 or 4 times and so far so good. I'll update if I continue to have problems.
I can't even get it to get past the rotating circle. How do I get it to reset to factory reset. Mind you I am in no way shape or form a computer genius so please respond in layman's terms. Thanks for your help.
Ive been having the same issue for awhile now and it seems most of the time its an app that is conflicting with Hauwei programming. if you get the black screen with green circle Click the Search Soft touch key and type in google play in the search and when you click the link tell it to use the app on the phone and uninstall the last app or 2 that you installed and than restart and should load fine.
Note you may need to uninstall a few apps or more depending on how many you installed.
Pull the battery click the power button three times slowly. put the battery back in and turn on. if you still cant get passed the circle. keep doign that a couple times. worked for me as i was stuck like you. then clear your internal storage. hard reset is power + vol up. im actually unable to get passed the huawei screen when booting into recovery
This is also correct.
