Algorithmic
Hello all, I just registered hoping you guys might be able to shed some light on my problem. My Huawei Fusion U8652 won't reboot into recovery
Here's how I got myself into this mess:
First I rooted my Huawei Fusion U8652 using the SuperOneClick method.
Then, unfortunately not knowing that I needed a special Clockwork mod for the U8652. I went ahead and just used ClockworkMod's "ROM Manager" app to Flash the ClockworkMod recovery. Once that was done I used ROM Manager to attempt to make a backup of the current ROM. At this point the phone tried to reboot itself to make the backup. However it was never able to get past the first screen where is has the large AT&T logo, and I had to eventually just pull the battery.
Now it still starts up normally, and I can use the phone fine. But if I try to reboot into recovery, or do a factory data reset, or anything that requires a reboot, it never gets past the first AT&T logo screen and I have to pull the battery.
Steps I've taken to try and fix this:
I tried to do a factory data reset, that didn't work, since it requires a reboot. Then after searching around for a bit I found this: AT&T Fusion U8652 Clockworkmod (CWM) Recovery manual | AT&T cell phones|AT&T Phones
and tried to use RecoveryClockmodByZaDkYn to install the recovery file. But because that requires a reboot when the device is plugged in, it wouldn't work either (my computer registers the device fine so that's not the problem).
I tried all the volume down/power button holding combinations and all of them result in getting stuck on that first screen and me pulling the battery.
My question:
Is there a way to manually install that custom recovery boot file from the RecoveryClockmodByZaDkYn? The phone works fine, including the usb connection and file transfer. It just won't reboot.
Also Is there a way to do a Hard factory reset? I would love to just start over and do this properly.
Thank you!!
My question:
Thank you!!
