Huawei Honor stuck on logo screen, fail to update too HELP!!
yoyooz
okay hello guys,
I have a problem with my Huawei Honor (GB B929 Rooted),
I wanted to install CWM, but I had to install bootloader first ... I tried to install a file called bootloader.bin with terminal emulator app ... after I Finished I Restarted my phone ,
the problem is It just freeze's at logo boot screen and shutdown after seconds .. I cannot access Recovery mod ,
the only thing I can do is to access pink screen with Volume UP + Volume DOWN + Power on .. when I connect it to pc it mounts me a disk with A folder named "image" have 5 files inside ... I tried to update the phone with b929 & b919 but no use at all it always says update failed
.. I formatted my SD Card but still no use at all .. I think what is stopping my phone from working is that bootloader.bin were installed inside the phones memory .. and I can't access that too because phone won't work ... what is the solution ?? what can I do so I get my phone back working ?? please help .. thank you
