Root Huawei M835 stuck at Android System Recovery screen
I was having problems with the superuser app and was trying to update it to a working version. Like and idiot i try to manually move the newer superuser files to where the old ones were located on the internal memory root. Bad idea. the phone crashed and now when i turn it on it will not go past the recovery screen. I have tried rebooting, wipe data/factory reset. I cant find any help anywhere on the net. Can anyone please help me or send me to someone who can.
only way out of this is to put the update.zip on your sd card and hold volume up + end button and power button . then root with superoneclick and flash your recovery and restore backup or use titanium backup if you have one . here the update.zip and instructions http://www.huaweidevice.com/worldwi...d=toDownloadFile&flay=software&softid=NDQwOTI= extract the dload folder to root of sd card . power off phone .. hold volume up+end call and tap power on clicks thanks if i helped :D
