Huawei Mate 10 Pro USB Port issues
Hello. Does anybody else have this issue that I have? I can't use Huawei Super Charge, it does not matter which charger I use, the phone will charge in 6 or 7 hours.
I do get a notification from the settings app, saying something about USB settings, but I can't change any of the options. It gets stuck to reverse charging and if I change the option, it will revert back to reverse charging in no time.
Has anyone encountered this problem or something similar and might have a solution?
Your next step might be to just contact the retailer you bought the phone from and tell them the SuperCharge function isn't working.
