Huawei Premia 4G or LG Motion?
mill3rkydd
So yesterday I found out my sister lost her iPhone and was forced to get an android (gasp). So my mom told me once I get back, that I can get her phone (Premia 4G). So far, the only difference I see is the screen size and storage capacity (I have a 16GB Micro SD card though). So should I just move to this phone? Thanks~
Well, the answer to that question would have a lot to do with how much you like the device you're now using.
Were you considering changing devices prior to the situation with your sister's iPhone? If so, why, and would the Premia resolve what issues you may have had?
If you're going to be out shopping for phones, you might as well get some hands on experience with the one you're thinking about; maybe that'll help you with your decision. :)
Well at the time, I was thinking of maybe switching carriers because of the freedom of getting other phones, but I thought that a bigger screen might help so I was just gonna switch.
The Premia has a better ppi and a bigger screen compared to the LG.
However, the LG's battery is larger. That with the smaller screen should grant you better battery life than the Premia.
Also, the LG has 1080p video recording as opposed to the Premia's 720p.
Those are the main differences I see between the phones.
