Huawei smartwatch not connecting to my Iphone6s
znipznip
Hi , i have a problem ... i got the huawei w1 smatrwatch , i updated to the latest version, i got it connected to my Iphone 6s amd worked fine ... limited by ios but ok for my needs , but if i take my phone out of range from my bluetooth when i come back they are disconected ( normal thing) and if i tap the reconnect card on huawei it doesnd connect back (reconnecting fail).. i checked if i have bluetooth connected , i restarted the watch , i opened the android wear app from ios again ... just doesnt reconect back.... the only way is to unpair and factory reset it every time ... can someone help?
I'm not exactly sure that the issue lies with the watch, as I connect mine to my Android phone daily with no problems. Your question is better suited in an iPhone forum, or maybe ask the Apple helpdesk about it. Good luck :)
You shouldn't need to factory reset. I have a friend with and iPhone paired to a Huatch, I'll ask him. I know when I first got the watch I had trouble stay8ing connected. I'd have to power cycle either the phone or the watch to get it beck connected. Still a PITA and unacceptable, but easier than a factory data reset and syncing again.
Is a Huawei Watch actually supposed to work with Apple iOS, i.e. is it officially supported by Huawei for doing this? What app are you using on iOS, is it from Huawei or Google, or something else third-party? Because I can't find anything like that in the iTunes Store. Also when I saw a Huawei Watch promotion show downtown a few months ago, it was all Android devices, nothing of iPhones at all.
Apple iOS often tends to work best with their own things or "Works with iPhone" devices or whatever, e.g. Apple Watch.
