Help I am having a known problem with Android x86 not booting
Hi there, I have been trying to install Android x86 for the past week but I can successfully install it but after install I get a Command Prompt type of environment instead of the welcome page. This has been a problem for me since I started to try installing Android 8.1 Oreo. Please look at the screenshot and tell me what is wrong.
I hope someone can help me.
Thanks
Alissa
Yes, you need to partition it this way in the video and have usb 3 instead 2 usb 3 is faster looks blue thick port on modern laptops usb 2 old computers thin black port looks also try using ssd they are small fast and cheap they work on usb unlike ata drives they noisy heavy and expensive and usb are little pricey slow and laggy for better experience if u can upgrade it by paying ur welcome :)
https://i1.wp.com/promotionaldrives.com/blog/wp-content/uploads/2019/01/dasda-usb-2.0-vs-3.0.jpg?resize=768,326&ssl=1
https://promotionaldrives.com/blog/usb-2-0-vs-3-0/
