I am having trouble charging my phone
  • Start date Start date
A
Android Question
Guest
I have a Droid 4 and it has issues when charging. It seems to not stay connected to the charger even though its plugged in.
That's usually a sign of a damaged cable. If your charger has a USB cable into a plug, try replacing the USB cable. If it's a charger with a built in cable, try replacing the charger.
Cables and chargers are pretty cheap - I just got 3 USB cables for just under
