sarvhim
Hello,
I simply did a reset on my LG L70 Dual D325 using the settings menu. Now it is showing secure booting error and then Demigod Crash Handler: DBI Err Fatal !
[1st screen:
ERROR: boot certification verify
Secure booting error!
Cause: boot certification verify]
[2nd screen(purple background):
DemiGod Crash Handler : DBI Err Fatal!
Board Rev.: 1.0
Ram dump mode.
Option : SD card ram dump mode.
Push below files to sd card before test.
rdcookie.txt, rtcookie.txt
Please do following action.
1) Ram dump Mode. Please connect USB.
2) Get the ram dump image using QPST Configuration.
3) If sdcard ram dump enabled just wait for reboot.
4) Collect ramdump files from your pc or sdcard.
5) Send e-mail to W5-BSP-Global@lge.com]
I have not done any modification to my phone at all. No rooting, no flashing, no OS upgrade, nothing.
I tried hard reset, no luck.
I tried searching forums but couldn't find solution to my problem.
Please guide me
Thanks
[1st screen:
Board Rev.: 1.0
Ram dump mode.
Please guide me
Thanks
