sorry this thread won't teach you how to tether.
I can tether with the native hotspot app on my phone. it's an older android I no longer use.
I couldn't always make tethering work on it. im not sure what I did exactly but tether works. no it's not apart of my plan either. I have another phone on the same carrier ...same plan doesn't work.
MY WHOLE POINT OF THIS THREAD IS THIS QUESTION:
how should I go about using tether WITHOUT allowing my carrier to find out?
im a bit afraid to use tether on a regular basis without first taking a preventive measure to keep this good thing going
so what do you fellow tether user use?
btw I also installed cyanogenmod rom if that helps(tethering also worked on the stock rom too)
