Root I can't restart my phone T939 after using Odin
Hi all
Can somebody help me !!!
I just use the Odin multy downloader 4.03 to reboot my phone (samsung T939) , but then when the phone pass , it just flashing the android 2 logo some time and then flashing the emty baterry ...
How can I do now ? Can somebody help me please ...
Please , can somebody help me ?
1. Download and unzip the file T939UVJE2_OEM.zip
2. Open up Odin Multi Download
3. Under Options, check One Package.
4. Under Select OPS, choose Behold2.ops
5. Under One Package, choose T939UVJE2_OEM-OnePackage-20100701.tar.md5
6. Power Off Phone (Remove the battery and then reinsert)
7. Hold and Press Volume Down, OK, Power (the red end button)
8. Phone will say Download Mode
9. Connect your Behold 2 via USB (install the driver if the PC required)
10. Click Start on Odin Multi Downloader.
11. Wait of six minutes
Enjoy
Enjoy
Hi
Thanks for your help , but it's the seem , can you help me the way to repair phone's core ?
:mad:
You go to the link and download the ROM T939UVJA3 (Android 1.5).
Extract the:
Behold2.ops T939UVJA3-Bootloader-20100318.tar.md5
T939UVJA3-PHONE-20100318.tar.md5
T939UVJA3-PDA-20100318.tar.md5
Using Odin for Up ROM.
** The link above, there are other original ROM. You can download and experience!
Sorry for my English!
I also encountered a similar problem as you!
After I use the following command:
adb push location file\su system/bin
adb reboot
su file by ROM BH_MAN_WarHeads
And then my phone will not boot up again.
The logo flashes "Samsung Behold 2" when reboot
Or the logo "Pin" when charging
My phone is using:
ROM: T939UVJE2-OEM
Recoverry: BH_New_recovery_matched_kernel_rfs
I tried the flash all the ROM version that I have collected. But still no fix!
CAN YOU HELP ME ! PLEASE
