I do not want to connect to select WiFi
Alztybrn
Hello all...
Is there a way I can get my phone to NOT automatically connect to certain WiFi connections? (other than turning my WiFi off completely...I always forget to turn it back on)
At work, the wifi connections have too many filters, so I want to use the 4G at work.
So...can is there a way to disable just my work WiFi so it never connects?
Thanks!
Hello all...
Thanks!
Easiest thing to would be be to forget the wifi networks in the settings. For me I still had some issues So I rooted and removed the auto connect and WIFI notification that way. Simple fix is to remove the network, download anycut ( link for it in the thread do a search for wifi notification) and follow the directions that will stop the Annoying pop up.
