i have 8g sd card but still requst for sd card
  • Start date Start date
A
Android Question
Guest
I have 8g sd card in htc one phone and can download from store but de others it will requst for ad card again( insert sd card )
Sounds like your card is failing. Try and remove the card and clean the contacts with an eraser and re install it and see if it helps. SD Cards do eventually Die some much faster than others.
