I have an ZTE prestige 2 having SD Card Issues.
When I turn my phone off about 90% of the time when I turn it back on it says corrupt SD Card. I have to open the back up pull the SD Card put it back in then it recognizes it again. The issue is every time I do that I have to redo my screen with all my shortcuts for all the apps on the SD Card.
How can I get it to not say its corrupt and have to go through this process every time?
Thanks for any help!
Before you do ANYTHING ELSE
make sure you have copied any important data on those cards to somewhere else... BACKUP BACKUP BACKUP
(then worry about fixing it later....)
