B
Babybaby123
Guest
I Have a Moto E4 Android 7.1.1 and there is a problem with the wifi. Now first let me say my router is on its last legs. We've had it for years and this problem arises only recently but I don't think that's the problem. My mom's router is like, a month old and the problem persists on that wifi too. Data works fine as far as I can tell, though I don't use it too terribly often so I'm not 100% certain. The things is my wifi will work for a random amount of time, usually no more than 10 minutes, but then whatever I'm doing that uses wifi won't load. Like if I'm watching a video it will show an endless spinning wheel. Or if I try to load a website the progress bar stays on the left side of the screen. But my wifi is on. With bars. And it's not saying "Connected, No Internet" it says I'm both connected & have internet. But the wifi just doesn't work even though it says it's on. No other devices in my house do this. Also, if I turn my wifi off, manually, (Manually is something Google search didn't understand, its search results seemed to make it think my wifi was shutting itself off and on) on my phone, not my router(or modem; I might be using the wrong terminology) and then turn it back on, it'll work again... For another 10 minutes at most and then the problem will happen again. I've tried restarting my phone and unplugging and plugging both routers to no avail. Does this sound like a hardware issue? Should I change a setting? Help. Please. Thank you.
