I need a blue tooth kb!
torero2
Hello guys, I'm on the road a lot of the time and very often I have to type minutes and reports in my tf101. the question is: has anybody used this Kensington KeyFolio Expert Multi-Angle Folio/Bluetooth Keyboard Case for 10-Inch Windows/Android Tablets and if you have, what is your opinion of it. Thank you for any imput you have on it.
Maybe a dumb question, but if you have a Transformer, why don't you just get the dock? It also charges the tablet and makes it seemless to carry. I have it for my Prime and love it.
I have a relatively inexpensive keyboard for my TF, it works fine. But I have to agree with Dreadnatty, if you're going to spend this much on a keyboard, why not spend the little extra and get the official dock?
Thirded. I love my dock...in fact I can't imagine using the Transformer without it...well, I can, but I don't want to. :)
thank you guys and I do see your points, but I don't want to add to much more bulk nor weight to my, already full bag. Plus I just thought that this Kensington folio was thin enough to avoid that scenario. I myself haven't seen it yet.
Assuming you're currently keeping your tablet in a case/cover, I don't think swapping that out for the keyboard would add much in the weight or bulk categories. YMMV of course. I just think if you're looking at spending more than $50 or so you should just go for the keyboard the TF was designed to work with.
Anyhow, I hope you enjoy whatever solution you decide to pursue!
