L lovalink Lurker Sep 20, 2013 #1 PLS MY huawei u8510-1 is having a problem ,the screem freezes all the the time
Rush {<>}~{<>} Sep 21, 2013 #2 Hopefully 'resetting' the device should be all you need to do to get things back up and running smoothly. Good luck. And thanks for joining our site. Note: you can find some helpful tips & info inside your device's support forum.
