i need help finding two apps
the app that turns up ur ring tone volume very high....wat it it called......and sorru its only one app
I know what app you're talking about. I just can't remember what it's called. I think I have it on my G1. I'll check for you and let you know. Heads up though. I'm pretty sure you need root to use it.
Sent from my Cliq XT using Tapatalk
