Root I need help flashing a rom
Dvncn
I can't flash any rom that isn't designed for the huawei u8160 on my huawei m835. I heard that the roms for the huawei u8150 also work on the m835. I tried to flash a u8150 rom, but everytime i do, I get an error.
The error reads something like this:
||getprop("ro.build.device")==u8150 ||getprop("ro.build.product")==u8150
- And it repeats that a couple of times. At the end, it says (satus7)
- I'm new to all of this, so I don't know what all of this means. If someone could help me fix this problem, that would be very helpful. I would like to be able to flash u8150 roms. Please help!
- P.S. I also tried to flash huawei ascend roms and the same thing happened. I can't flash anything that isnt u8160. (could this have to do with the type of clockworkmod I have, and if so, how can I flash different version of cwm? For example, a version for the huawei u8150)
H'm... do you guises need the u6160 recovery image? I have hat if you need, I also have a custom recovery installer so....
Holla at me?
