I'm not quite sure those are good reasons to go through the process of rooting, especially since this will involve kids. Yes rooting allows one to do a lot of things, but for the inexperienced it also greatly increases the odds of bricking your device. Also, rooting 1 - puts all the responsibility and maintenance on the user (things like Google Play app updates go on as usual but operating system upgrades/updates/patches need to be applied manually), 2 - increases the risk of malware and other such compromises to affect the operating system (when non-rooted, the majority of exploits do not have access to the OS), and 3 - a number of apps and online services, such as Android Pay, Netflix, Pokemon Go, won't work on a rooted device (there are some stop-gap workarounds to 'fool' those apps/services that a rooted device is not, but they're not an absolute, catch-all solution).
Also, the idea was not to have these connected to the internet. Does that make a difference?I'm not quite sure those are good reasons to go through the process of rooting, especially since this will involve kids. Yes rooting allows one to do a lot of things, but for the inexperienced it also greatly increases the odds of bricking your device. Also, rooting 1 - puts all the responsibility and maintenance on the user (things like Google Play app updates go on as usual but operating system upgrades/updates/patches need to be applied manually), 2 - increases the risk of malware and other such compromises to affect the operating system (when non-rooted, the majority of exploits do not have access to the OS), and 3 - a number of apps and online services, such as Android Pay, Netflix, Pokemon Go, won't work on a rooted device (there are some stop-gap workarounds to 'fool' those apps/services that a rooted device is not, but they're not an absolute, catch-all solution).
So if I leave the Nook as is, will they be able to read both epub and azw formats on it? And listen to audiobooks?If these tablets will be restricted from any online access, than rooting them isn't as big an issue, at least as far as online exploits. But without online access, this requires you or some other adult to manually transfer that media content (ebooks, audiobooks, etc.) onto the tablets.
Perhaps an alternative is to just leave those tablets as is but set up Parental Controls, restricting your grandchildren to use only the specific apps you've chosen for them to able to use. This leaves the parents and you full access when you need it, but limits the kids to just a few things.
https://www.wikihow.tech/Set-Up-Parental-Controls-in-Android
I'm trying to provide a device for listening to and reading books, both epub and azw that are loaded via usb cable or such from the parent's computer. I would happily leave the Nook alone if I could do that without the Nook trying to connect to Barnes&Noble.Since you were looking into a Nook based solution, don't forget about getting them a Kindle. Use the Kindle Parental Controls to restrict the kids to just the ebook and audiobook apps, plus the Kindle Paperwhite has that great screen, designed to be suitable for indoor or outdoor reading. Better than a typical tablet screen if the kids like to sit around outside.
He, is Kindle android?Since you were looking into a Nook based solution, don't forget about getting them a Kindle. Use the Kindle Parental Controls to restrict the kids to just the ebook and audiobook apps, plus the Kindle Paperwhite has that great screen, designed to be suitable for indoor or outdoor reading. Better than a typical tablet screen if the kids like to sit around outside.
Can they read epubs on the Kindle? And can I totally shut out Amazon? Same with Nook. I don't want there to be an interface with a retailer. That's the goal.Hi, I replied to you without using the reply button. If you read the thread you will see that I thought I was communication with you!1st off, what is the reason for rooting?
A Kindle's operating system is FireOS, developed and maintained by Amazon. FireOS is running on top of Android but its user interface is all focused on ties to Amazon online services.
But your thoughts on getting a Nook, or a Kindle, might not be so practical as you're also very averse to having the tablet tied to a retail store. Both model lines are specifically designed and branded by their respective sources (Barnes & Noble or Amazon) so you'll be putting in a lot of time and effort (and possibly extra money) to 'sanitize' them. Have you looked into a Kobo maybe?
https://thewirecutter.com/reviews/amazon-kindle-is-the-best-ebook-reader/
