I Need Help Sending A PDF From Windows To My Note 10.1
Hi all
I've installed Kies on the computer, and got my Samsung Note 10.1 hooked up, I need to store a big heap of PDF documents on the tablet whcih are currently on the computer.
I've got the tablet folders up on My Computer, but I'm not sure which folder to store them in so that I can easily get to them on the tablet.
Thanks in advance! :)
Put them in whichever folder makes sense to you (i.e. where you'll remember you put them), then just use a file explorer app to select and open them.
