1. Turn on wifi in Settings
2. Make sure you are in range of the wifi access point or router
3. If it's an open or public wifi, your device will automatically connect
4. If it requires credentials, go into wifi settings and look for the SSID ("name") in the list. It should be near the top of the list and likely have the strongest signal.
5. Tap the SSID name, enter the password, and press Connect.
6 You should be connected shortly
