Root I need help
haroldJ99
Member
i have my lg l70 ms323 with cwm and the symplicit rom and my little sister grabbed the phone and now dont turn on stuck at the lg logo what can do ?
how to enter to cwm with the phone off ?
Alright, power off device, power on the device, and wait until it gets to the dim LG logo and try to interrupt the long vibration by pressing volume down a few times, if done correctly, your phone will stop the first boot and start another one that boots you to recovery. Timing is key so it might take a few tries
not enter to cwm i dont know whats happening
hold volume up and plug in your charger at the same time.keep holding vol up .if u go into fastboot instead of recovery,u will have to use the unbrick guide to fix it
please help my phone is stuck at LG screen and in fastboot mode. I need to get into stock download mode but when I try to restore LAF it doesnt work. I can get into CWM but formatting doesnt help
