Help I need some help with my contacts
yarniac
Hello! After I purchased hubby's Atrix hd, I had to go to the ATT store to get the contacts moved. Somehow, they put the contacts in a PEOPLE folder.
That is somehow different from his contacts folder! When he clicks the phone icon, his contacts are not there, and if he received a call, no caller ID.
He can make calls from his People folder, but that isn't good enough.
How do I sync the two?
I don't want to go back to the dreaded ATT store:)
Thanks
You could try connecting the device to the PC and finding the contacts in the People folder and move them into the Contacts folder.
Thanks... I tried that. I downloaded and installed Motorola Device Manager but the only option I got from that was to update my software.
I may need to do a search on how to use the software :D
