Smarmylamb
I flashed the new Adreno v3 [MOD] New adreno libraries 04.01.01.00.036 V3 (FOR DEVICES WITH ADRENO 2XX GPU ICS) - xda-developers drivers with Flash Gordon [APK][Flash Zips WITHOUT a Recovery!]Flash Gordon: an Edify to Bash parser/translator - xda-developers and now my Event lags so bad and only the launcher works without not responding unlike other apps but the launcher still lags sooo bad but luckily it still boots up so there's hope in fixing it with adb also the boot animation doesn't show but you can here the sound and doing anything on the device lags badly. I tried to re enable cpu and gpu rendering and at first after I saw the boot animation I thought I had a temporary fix but then I couldn't use any apps except launcher cause everything would force close. I downloaded the system folder and copied over the files that were replaced by the Adreno v3 libs, set permissions, I did all this with adb, and rebooted into recovery (stock) and cleared cache and rebooted but did not fix the problem. I really love his phone and one day if not today I would love to be using it again and playing games on it. If anybody can help can you please do so.
