I sync my podcasts with iTunes, is there a player that remembers position?
yegon
Not after a podcast manager per se, I'm quite happy syncing my phone with iTunes via iSyncr. However, the default music player on my spanky new Galaxy Note doesn't remember position, are there any music players that do?
Cheers.
If when you say "remember position", you mean that you can stop listening to something and when you re-open the app, it allows you to continue listening where you left off, I currently use the BeyondPod app and it does this and more. It's not free, but, take a look at what all it can do. In my opinion, it's one of the best android podcast apps available. I know you stated that you didn't want another podcast manager, per se, but, the only way I feel that you will be able to accomplish what you are looking for, will be to install a full blown podcast manager app, replacing isyncr/itunes/Galaxy Note default app alltogether. You can still access/sync all your current podcasts directly on your device instead of on your computer. Hope this helps.
