I think i have spyware on my lg stylo 3
Can you screenshot what makes you think you have spyware? Any suspicious looking apps that appeared that you did not install?
I reset that one now im on my stylo 2 but the 3 it wouldnt let me research how to get rid of spyware when i would tap on something it would vibrate real hard it was using storage and memory like crazy when i was searching for a solution pop ups covered my whole screen but a half inch across the middle pop ups in my apps that never had popups before and i found a folder in file manager that was never there before that said network connections and i got a warning about a remote connection
i have a file in file manager that says android secure and the date on it is 12-31-1969 i cant open it i cant delete it any one know what it is
You probably downloaded an app that installs adware on your phone since you had popups.
When you reset, was that a complete factory data reset which wipes your entire phone?
Yes you can... Try it and see what happens.
Or at the very least create a brand new account and sign in with that... and DO NOT INSTALL ANYTHING ELSE.
But hard reset should delete everthing i even deleted the backups and everything else i could delete but it was still there even deleted memory card if i make new account wont all that still be in internal memory
But after you hard reset.. the first thing you said you did was pull back all the stuff from your account.. and then the problem started again.....
If the spyware in the internal on your phone.. it will still be able to do things WITHOUT an account... or at second best with a DIFFERENT ACCOUNT.
but you don't know that yet... you are troubleshooting the device.
In the last 2 days these images r everywhere
I downloaded app hidden settings and it said credentials r bad and i found a lot of them with no name in drop down box is this normal
I reset it and stayed good for an houre then old account just appeared my apps r running like crazy when u open one app 10 more is running in it i used the hotspot on that one lg stylo 3 android tracfone with straight talk service and i connected my lg stylo 2 android tracfone it has no service so i use the hot spot and looked up how to fix it now its running like shit to
I keep finding parts of my stuff everywhere in storage ive changed my password 20 times this month and i had the same account for six years and all of a sudden it wouldn't let me in
