Root I think im bricked.
Hey everyone. my metro 910 started acting glitchy and froze after I applied e/s to basix. So i pulled the battery and expected to reboot but my screen stayed at the "Samsung" screen (before boot). I wast able to boot into recovery either but I was able to put the phone in downloading mode. And I was able to flash back to stock with Odin using option 1. and everything was fine for the night then the screen froze again in the morning so i pulled the battery again and the something happened but this time I cant recover anything though Odin.
Has this happened to anyone else is there something else i can do?
same problem happened. i flashed over multiple times everything in odin works fine its just when the phone reboots i have even let it go overnight and im still at the samsung logo.
Could i try to restore one of my backups through odin??ut
Ive read moost of the posts about "stuck on boot screen" or boot loop problems and they all say to use odin.
Which Odin image are you using? Do you have the Cricket or the MetroPCS version?
